OK. Shifter feel and smoother synchros are not signs that your oil is helping you. I don't know about an NG900 trans for point a below, but point b holds true for all transmissions.
a:
in a c900 trans, most of the "smoothness" or lack thereof that you feel in the shifter (not grinding) comes from the ball in the rear of the transmission. I would rather use an oil that has a viscosity similar to what saab intended to be used rather than one that lubricates this ball better. Apparently you can take off the rear cover, remove the ball and spring, regrease, and this may actually lead to a smoother feel. Never tried it myself.
b:
And now for a little deductive logic.
Desire 1: I want to have my transmission last a long time without rebuilding.
Desire 2: I want smoother shifting.
Starting from Desire 2...
-I want smoother shifting
-I add an oil that seems to make the synchromesh work better.
-The synchromesh works better because of increased friction in the synchro rings.
-Increased friction leads to increased wear.
-Increased synchromesh wear leads to decreased transmission life.
It appears that our desires are mutually exclusive.
To quote jetman on SC, "Notchy shifting's where it's at."
