Tricking the ECU???...More Boost?!
7.9K views 17 replies 12 participants last post by  Bullseye
I am no auto-mechanic, but from what I understand from the following article, the Viggen (and I would imagine other SAABs have the same feature) can run up to 20 psi to compensate for high altitude. Anyway to trick the system? :twisted:
"Although only 15-16 psi of boost pressure may be required to achieve maximum power and torque at or near sea level, Saab's Trionic 7 engine management system allows the turbo to produce up to 20 psi at higher altitudes to compensate for less dense air. The result is maximum power is available at altitudes approaching 10,000 feet. "
http://www.saabnet.com/tsn/models/2001/pr22.html
*This has probably already been brought up, but I had no idea on how to begin searching for it. Sorry if this is a repeat.
Id imagine youll cause Air Fuel issues as at altitude the air is less dense - requiring the turbo to flow at a higher pressure to make up for the density. In esscense your not making any more power at altitude, only more boost. If you trick it into thinking your at altitude (which would involve tricking the MAF) its going to think your flowing less air than you really are and wont provide enough fuel for the air you are flowing.
In English - youll run lean and could do serious damage. Save the money in the long run and get a tune if you want more power.
Yep. I couldn't believe I only had 11lbs peak boost the other night
(9 degrees outside) and the car ran like it was possessed.
Don't equate boost pressure with horsepower. There is an interrelation, but more boost does not necessarily equal more horsepower.
#7 · (Edited)
Haha on the baloon idea. To my knowledge on T7, which I admit is limited, a MAP sensor, if there is one, would provide a confirmation reading on boost used to determine air mass inside the manifold through density equation and the IAT like T5 does. I'll go search online to see if T7 cars have a map.
From euro.
Part Code: 9173386
Part Name: Air Mass Meter
Part Brand: Genuine Saab
Part Cost: $152.10
Part Core Charge: $0.00
Part Description:
Air mass meter (mass air flow sensor) for any 99-02 Viggen, 00-02 9-3 all, 03 convertible, 99-05 9-5 all.
Part Code: 9132374
Part Name: MAP sensor
Part Cost: $122.40
Part Description:
MAP sensor for any 94-98 900 turbo, 94-98 9000 turbo, 9-3 99-03 (not Viggen). Genuine Saab.
T7 og 9-3 have both maf and map.
Griffen, then why would eeuro go and list that all og9-3 excluding viggen had MAP's. I'm not arguing that the 9-3 t7's don't have a MAF, I know they do. Go and see if your 9-3 has a MAP though, it would be up on the left side (looking into the engine) attached to the strut bar.
