anyone fancy one? see here for more details....
http://www.uksaabs.co.uk/UKS/viewtopic.php?f=3&t=38308
Yes I supposed the great american tubular manifold group buy wasn't carried out by a similar sketchy bloke since Vince, whoever he is! Or the similar manifold spacer group buy, purchasers across the pond have put it down as a scam! as they cannot get any contact with clubsport on when they will recieve their spacer.^ Fair enough.
We're just saying that there are much better ways to make power with a TD04 then send it out to an unknown source who isn't up front about how they would make use of our money.
Hate to say it Brit. but you've come off as the sketchiest bloke since Vince from Sham-wow.
Loud and clear.there is nothing dodgy about this , the work is going to be done by one if not the best turbo guys in Britain the compressor wheel is a custom design between a 18t and 19t , the guys know what there doing so there wont be any "over grinding" of the housing.
Same for most people on here.crazybrightman just came on here to give some of you guys a chance to get in on this if you want , the turbo is plug and play and as said is performing very very well , and provides a very good driving car , with plenty top end for most , most of us in the UK use out cars as "street drivers"
A slightly larger turbo will provide the same driveablity w/o the draw backs. (See last paragraph for more on this.)and use them to work everyday , i suppose the roads in the uk esp. rural ones favours this kind of turbo set up lots of nice twists and narrow turns , and as such , a huge turbo wallop at 4 or 5 k rpm , is of no use , the car would be out of its comfert zone .
Again loud and clear. Sounds like a decent setup.a well know british tuner was selling hybrid td04`s , these are a big improvment on there design, and as said a 2 year warranty speaks volumes on how well this turbo will be modded and put back together.
This setup not ideal it's a compromise between: performance, cost, and effort to install. That hits a sweet spot for many. It's a worthwhile thing to consider. As for the reliability concerns of other turbos yes more cost and effort to install are needed. But, the reliability hit isn't has high as you claim. As a slightly larger turbo can be pushed to a higher limit than this custom TD04 yes, but it can reach the same output as this setup while working less hard to get there. Thus in the end you get actually get a more reliable setup due to less overall stress because the ceiling of what everything can handle isn't being bumped up against every time you go full throttle. Also just because a slightly larger turbo could produce +400hp doesn't mean you have to run it at that level.haveing a 400bhp monster is very well , i thought about a holset to instead of this , but as i use the car daily i need a somewhat reliable car , not something that requires constant attention , ripped out drive shafts etc , you can get to 400 bph really easy but making it a reliable 400 is another point ,
The hybrid td04 is good for 2 bar of boost day in day out , more than enough for me , but then again the sweet spot on this turbo will favour my driving style , and roads , so come on guys , no need for the dodgy comments..........
thanks
