Royal Purple 20W50 ok for Vig?
5.5K views 29 replies 16 participants last post by  Jack Straw
Just wanted to know if the 20 was a bit to thick for cold start on a turbo car. Of course I'm only thinking of using this in the summer. I have used Castrol 5W50 last summer and thought it was good. I wanted to try Royal Purple. I think Jameson is running it. Any one using a grade like 20W50?
Thanks!
P.S. Please keep the comments from turning into a Oil A Vs Oil B debate.
I've been using their 10w-30 for a year or two now. You seem to hear a little more valvetrain noise from the engine. But, it did improve mileage. HP increase was only 5hp so, that could have been any number of factors. One of the chain stores had it on sale for 6 bucks a qt a few weeks ago so I bought a bunch.
Your car has a thermostat and a cooling system. It runs at the same temperature, year round, except on start up. The only difference is that in the summer, it starts at a higher temp and warms up faster, which is better for your engine, and makes your oil perform better. Using different oils in different seasons is utterly pointless.
once it's at temperature. Unless of course your engine magically stores thermal energy when it sits over night in the dead of winter.
Same goes with driving the car really hard on the highway, entering the city on a 90 degree day and sitting in traffic. The cooling fan can only remove so much heat from the heat exchanger.
I guess your statement is more applicable to summer useage because the car is designed to regulate the engines temp.. But still I'd prefer oil which can handle more heat without losing visocity.
I don't know if things have changed much, but back when the turbos first came out we use to use 20-w50 in them and had alot of turbo coking. Granted back then the turbos were not water cooled either. But we were told that the viscosity additives were whar was causing the coking in the turbo bearings. When we switched back to using 10-W30 the coking problem went away. I personally feel the lighter multi viscosity oils such as 0-W40 that ia recomended is the best to use, light oil for starting gets the bearings lubed quicker and the heavy viscosity for the hot hard driving. This is my 2 cents.
Yes, it does change by temperature. That's why you buy multigrade oils like 5w40 that work well at all temperatures.
A 5wXX oil will be better for a SAAB at startup, regardless of ambient temperature. It just means that the oil will start out farther up the "temp vs. viscosity graph" than it would if it were colder outside. That's why you use it year round, and stop trying to out-engineer the makers of your car who devote their whole lives to studying and designing oil and engines and choosing the proper kind for your engine.
A 5w40 oil behaves THE SAME as a 15w40 oil at operating temperature. They used to preach "viscosity extenders reduce heat resistance" but synthetic oil technology has advanced beyond that.
I suggest you might want to look at buying an oil pressure gage. I see a huge difference in oil pressure from the winter to the summer and I am talking about when the car is fully warmed up. There is much more heat in the summer and my oil pressure drops down with rp 10w30 to where its marginal at best in 80F and up ambient temps. I have to switch to at least a 10w40 and will probably go back to a 20w50 for racing in the summer months.
Try opening you're hood in the hot summer months after beating on the car, it will cook you from 10' away;)
John
#28 ·
Ice I run 0w40 in the winter and 15w50 in the summer (both mobil 1). Anybody that says it doesn't matter what oil you run probably has never had an oil pressure gauge hooked up to see the values as they change in regard to outside ambient temp.
I know that in my car an 0w-40 as outside temps approach 60 or higher continues to drop from ~40 psi at 2000 rpm to ~30psi at 2000 rpm. The higher the outside temp the more it drops. Idle becomes really scary to think about. With my 15w-50 I see ~40psi at 2k no matter what. There is a reason that saab, at least for the b2x4 series motors, included in the manual different viscosity grades for ambient outside temperatures. It was so that owners would have the proper oil pressure at 2000 rpm as stated in the WIS system that techs have access to.
Now the one thing I don't have is oil temp by oil grade in relation to the change in outside ambient temp cross referenced to oil pressure. Maybe I'll have that for you all one day.
