So I have a 3" DP with a hollow cat. I was under the impression that because it looks like it has a cat and the ECU is tuned to not throw a code because of it, it would pass inspection. FALSE. The scanner can tell that the rear O2 sensor is turned off, which somehow makes 2 codes look like they've been cleared recently. You can have one code undetectable and pass.
Questions:
1. Does anyone in NY have this setup and have a magical way of getting around it come inspection time?
2. Will the cat that I just ordered from GS (the one that comes on their 3" downpipes) do enough emissions control to not have the rear O2 sensor throw a code once it's turned back on?
3. The cat I bought is here:
GenuineSaab.com
Does "slip fit" mean it doesn't need to be welded?
Questions:
GenuineSaab.com
