i know this is a common topic, but after reading over many many posts, none seemed to match up with my current situation. so please forgive me if this is a repeat. anyway, heres the problem:
i have a 97 900se w/cold air intake, forge bov and dawes device mbc. in it's prime about a year ago, i could push about 12-14 psi all day long. the turbo would spool up, and hit 15.5 right before fuel cut, and hold at about 12--14 psi. lately, my boost levels are consistently low. turbo spools up, and levels hit about 10psi and taper off to about 8psi. any ideas on what could be robbing my boost? I have replaced all vacuum lines, and checked all seals surrounding the delivery pipe, ic piping ect. and i have found no leaks. also, i have adjusted my mbc to the max pressure, and stretched out the spring inside. The rod attached to the wg actuator is attached properly and has never been adjusted. any input would be helpful, i would love to hear that turbo spooling at 15 psi again soon!!
