technically methanol is race gas, if i remember correctly the use it in f1. the main reason for methanol injection is to dramatically cool the intake/exhaust temp since it burns so cool. If you strictly ran on methanol you wouldn't even need an intercooler. due to this methanol also allows you to run more boost safely because it stabilizes pump gas so it takes more pressure/temp to ignite. but even if your not running more boost, you will get a noticable performance/response increase because of the density of the charged air. with a good injection system you should be able to get an almost 15% gain, in some cases more.
However, you must be careful when using methanol especially if this is your primary fuel. due to its extremely low specific gravity, it requires almost twice the fuel by volume than gasoline and then you will need ridiculously large injectors. So injection is perfectly safe as long as it directly injected into each cyl, but if its one of those crappy single injector into the intake charge pipe systems,you'll be safe with stock boost, but i'd make sure you do not try to turn up the boost too much since you have no way of telling how much methanol each cyl is getting.
