I have read a few flickering lights posts. So here is my info.
If your interior lights are flickering, It can possibly be 2 things. (maybe more) On thing to check is the light sensor, located next to the clock in the SID. Cover it with your finger and see if any intensity changes in the interior can be detected. Do this at daytime and nightime. Because nightime, is the right time....I believe this means you will need a new sid.
If you can press on the thumbwheel on the interior light dimmer, and have the lights come back on, then you will need to replace the unit. It simply pulls out and unplugs. This was my problem and probably the cheaper solution to fix.
