Don't forget to remove the fuel filter before dropping the tank.
Soak the hell out of the gas tank strap nuts with a rust penetrating solution. Then buy replacement straps because yours break or get twisted to hell.
The less gas in the tank, the better.
Silicone spray on the fuel pump elbows to aid in disconnecting the fittings, rotate them back-and-forth slowly while gently pulling up.
Hose clamp pliers for the fuel filler rubber hose to prevent fuel from coming out. Also have extra hose clamps to replace the ones that are likely rusted and seized on the rubber hose.
Easiest to drop the exhaust in the back and the heat shield, but it is possible to drop the tank without doing that.
