Engine mount bolt snapped
7.6K views 23 replies 10 participants last post by  laxian55
Heard a slight pop on a gear change, didn't think much of it. Pulled into the parking lot about 1/4 a mile later and hear a *clang clang* of metal hitting the ground. Park the car and look, pick up a metal plate from the ground. Realize that its the metal plate from the genuine SAAB poly engine mount. Look under the car and the oil pan is resting on the subframe. Feel in the hole and the bolt is loose, pull it out and fuck its snapped. Mount has been in the car for almost a year now no problems. Just did a transmission job if that matters.
According to the WIS, the engine mount attaches to a bracket that can be changed, that also hold the A/C compressor on. Do I just need to take out the 3 bolts holding the compressor on and pull the mounting plate off? And yeah I'm drunk now *shrug*
I would say changing the tranny had something to do with it, if you "sagged" the motor. Which you pretty much got to do to get the tranny off.
The standard engine mount has a lot of movement in it (being rubber) but the GS mount is solid. If you were to do it again with the GS mount I would undo the two mounting bolts 1/4 of the way so that when you "sagg" the motor there is not so much pressure on the mount and the movenment will be in the loose bolts. If all that makes sense !
Changing the mount is a piece of cake.
place a jack under the sump with a piece of wood between the jack and the sump.
Jack it up , taking pressure of the mount.
Undo the two top bolts (attached to the chassis) and the "allen key" bolt, Attached to the motor.
Wallah, mount is now removed.
Sounds like you either had a bad bolt from the factory or it was mixed up with another bolt or maybe over torqued. Did you use a torque wrench originally? Depending what order you do things it would be pretty easy to get in the situation where a 1/2 breaker bar and allen socket would be the combination that gives enough clearance and length to get on it, which would make it pretty easy to overtorque. It's a weird failure, if everything's right that bolt should be more than enough.
That bolt looks very suspect to me.
It's like it's corroded on the end of it.
Something has been eating away at the metal and caused the failure.
High tensile bolts like that don"t just snap.
I smell sabotage!! :)
Or you used battery acid as thread locker :(
