so just got a set of T5 cams for my car. now to just put them in! got em for a steal too! anyone know if they can just drop in or should i get a tune? wicked excited for this!
Casey
Casey
yeah, in your case it might take a very short time ;pnot long... the time is doing the timing, gotta get that right!
Rafal you gonna come get your parts or what?! lol
Casey
What he said.Pull the 12 mm bolt on the spring tentioner, ziptie both gears to the chain and unbolt them via the 14MMbolt holding them in, then pop all the 12 mm bolts holding the camshafts in... insert new cams, align cams to sprockets, which cannot jump any teeth because they are zip tied. Torque the cam caps down, torque the 14 mm bolt on the sprocket to 63nm, and turn the motor over 2 times to check your timing marks.
This method makes it just about impossible to time the engine incorrectly!
