Hallo to all!
Well, i dont have a saab, but i want to put the title engine/s into an
opel speedster/vx220. My current engine is a z22se which uses the F23
gearbox and i ve read that the saab engines are a direct bolt on.
So, to cut to the chase, i want to use a b206 which doesnt have the
balance shafts (every kg is importand), but i want the strength of the b204L/R.
I ve also read that i can make a hybrid with the b204-b206 bottom, the
b205 head, using the b204 cams and gasket and volvo springs.
Are the internals of b206 as good as the b204's, or just the block?
Any suggestion/help/opinions are more than welcome!
p.s. where can i see the code number of th engine, on the engine? I had a
look today to some saabs and i found one write B206Iblah blah on the registration
and an other write B204Iblah blah but i couldnt confirm it on the engine.
And they looked pretty much, the same. With black top, not red.
Thank you very much, in advance!
