no, that will cause the ABS pump not to run, and thus with the ABS+3 System the C-900 uses, you would HAVE NO BRAKES! well, not none, but 10% of normal braking power.
An ABS light should be fixed correctly, it's not like an airbag light. an ABS car should have working ABS as it's quite an integrated system on the C-900's
