Have an issue with the cooling fan on the Aero. Both fans won't come on causing overheating issues. I hit the fan with 12v at the coupler on the fan, and it works fine. The Thermocontact Switch (3 wire) switch is corroded, and ordered a new one to see if this solves the problem.
If I hit the connector with 12V does this mean that the expensive cooling fan and resister are good?
