Status
Not open for further replies.
1999 Saab 9-3 2500$
867 views 12 replies 5 participants last post by  mike d
Up for sale is my 1999 saab 9-3, it has a lot of recent work done, however i am getting a new car soon, and no longer need this one,, In the last 2k miles, this has been done
-New clutch, and slave cylender. Clutch is now Viggen spec
-New trans mount
-New oil pressure switch
-New front control arms W/ball joints
-New Stanton arm bushings (Polyurethane )
-New sway bar end links
-Multiple new coolen hoses, with repaired cooling fan low speed resistor
-New Direct ignition Cassette (OEM saab, not a cheep aftermarket)
-Replaced Exhaust manifold studs. (common issue)
-100% fluids and filters changed.
-New windshield wipers
-New interstate battery
-New blend door driveshaft
-Oil pan removed, cleaned, re-sealed (no issues, i did it while the trans was out for clutch because it takes 10 minutes to do then)
-Stage 1 Mike D Tune!!!!
What was done by the previous owner in the last 20k miles
KYB shocks on all 4 wheels, with front shock mounts
brakes
remanufactured ABS modual
remanufactured SID unit
Cat back exhaust, still in great shape
Radiator
Lastly, if the asking price is met, i will include some new, never mounted Blizzak WS70 snow tires. So new the stickers are still on the tires!
Status
You have insufficient privileges to reply here.
