I've been meaning to do a writeup on this build for a while. It's long so I'll be adding it in pieces.
In its previous life this car was a tired, 200+k mile daily driver from Santa Cruz, CA. It showed up on Craigslist for $500 right when some friends of mine were looking for a first project. They weren't necessarily looking for a Saab, but since I had experience with these and spare parts lying around, and the price was right, that was just the icing on the cake. I agreed to host the build at my shop and help out. Before I knew it I was really attached to and excited about the car, became a partial owner and devoted a lot of time to it.
Three of us took the drive over the mountains to inspect the car in person for the first time and see if we could drive it back (if not we'd make another trip with a trailer). Poor car was in rough shape. The starter would turn and make horrible grinding sounds but not actually engage or turn the engine over. We pushed it out into the street, hooked it to our truck with a tow strap and after a few attempts managed to tow start it. The exhaust system leaks everywhere and the cab quickly filled with fumes.
We tried to get the windows down to make sure it was safe to drive home, but none of the power worked. I ripped off a door panel and tried to touch jumper cables from the battery directly to window motor leads, which clearly wasn't going to work. I ended up using a screwdriver to crank open the sunroof manually and just leaving the windows up.
The tires were all flat and the gas light was on, so we crept up the street to the nearest gas station and filled up with the car still running since we weren't sure if we'd be able to start it again. Turned out the gas gauge just didn't work, but at least now we knew it was full. We filled the tires up (which were also bald) and set out back over the mountains for home. One friend led the way in his truck, the other rode passenger with me and held one of the sun visors out of the sunroof to get some fresh air in the cab. There was no spedometer, the steering was rubbery and unresponsive, and the shifter was almost completely shot. The drive home wasn't as bad as I feared it might be, we made it back in one piece and parked the car.
