1 - 2 of 2 Posts
Hi guys, I recentlty got a hold of a volvo pegs set, and I know I will be needing wobble bolts but i saw on some posts that other people have used their regular bolts, is this true? and if it is, is it safe to use the regular bolts? thanks guys.
Super Moderator
5x110 vs 5x112
That is a 2mm difference spread between 5 lugs. This means the stock bolts would probably work fine because the hub is what centers the wheel. I would test fit them with stock bolts and eventually buy wobble bolts if I was uncomfortable with the fit.
1 - 2 of 2 Posts
