My 9-3 has a single fan and runs at low speed as soon as I turn the a/c on and high speed when the engine gets up to temp.
It has two relays for this. Low speed feeds power through a resistor and high speed feeds power to the fan, bypassing the resistor. It is a .25 ohm, 50 watts resistor.
Here's info to help:
http://www.saabproject.com/NG900SET/Rad_fan/fan_test.html
You should be able to wire something up from this.
Good luck.
Good luck.
