1 - 7 of 7 Posts
i have BBS RKII's, they are 17 inches in diameter and 8 inches wide. i already have problems with rubbing but i really want to lower it with the koni springs from gs. how much worse will it get? anyone have some remedies?
Uh, well, if it rubs now then it's ging to rub even more. What size tires do you have as you could change those to help some, plus you could go with eibachs which don't lower it as much as vogtlands.
What about wheel spacers?
Are you rubbing on the inside part of the tire or the outside? My e36 rubs ever so slightly on the inside so spacers should take care of that along with a fender roll. If you're rubbing on the outside spacers wont do you any good.
1 - 7 of 7 Posts
