1 - 20 of 56 Posts
Hey guys, do you guy know if the NGK LASER spark plugs will work on a 99 93? Or just the regular ones will only work ? I tried looking it up and it seems that it only has it available for 2000 and up. So i don't know ? Maybe it's only for T7
only use OEM plugs!!!!!! Anything else and the car will A. run like shit B. Burn out your d.i. cassette and C. the motor wont be able to detect knock
If it wernt for Saabs, NGK would be out of business.
I'm guessing that you are joking.
Powersports and Motorsports have nothing to do with it*
I keep blurring the line between TSL and the real world.
I keep forgetting that theres no implied sarcasm in the webs.
I figured you were being sarcastic...you just need to make sure to add the *
On N/A SAABs you can use other stuff, but Turbos must get the OEMs. That's because your DIC uses the plug to measure engine parameters, and only the OEM NGK plugs are proven to give the DIC the correct readings. You can go ahead and try other plugs, but you've been warned.
if you are going to a parts store to get them the ones you want are bcpr7es-11
I have a Viggen and purchase the bcpr7es (not the -11's) from the local carquest because they let me purchase them per box at a little discount.
The -11 is just the gap - and that's something i can do myself easily.
They are a little less than $2 a pop. I do not buy 'Saab' branded plugs.
I do replace them between 12 and 15K miles.
46K miles, and no issues.
Andrew
im running autolite plat plugs with a t7 cassette in a t5 engine. been running for 10k miles and no problems, performance issues or cassette issues. Reason? I needed plugs asap and i couldnt localy find the NGK's im "supposed" to run , so i resorted to these thinking i was going out on a limb...no...im doing just fine. OEM is not a must.
just sayin.
1 - 20 of 56 Posts
