Although I am sticking with my T5 cams until I am up and running, I thought I'd flesh out what different cams folks have run and how they like them or otherwise.
Power figures are GT3071r 0.64 approx. Probably more useful to state 'difference' and not actual power I guess. I've picked up some of the bhp suggestions from earlier posts.
1) Stock T5 - 400 crank possible?
1) 260 / 9.2 Reground stock T5 cams. Not convinced these give decent gains for the investment. No adjustable wheels needed though. Just drop in.
410bhp crank?
2) 260 / 9.5 Higher lift - Shouldnt kill the bottom end either??
420bhp crank?
3) 264 / 9.6 Look like a nice balance opening up top end. Genuine saab only. I am thinking these could be a good option for road use??? Not sure if I NEED uprated valve springs. 435bhp crank?
4) 268 / 9.6 Seems most common on this type of turbo 0.64 and 0.86. Better with uprated valve springs. Might limit benefit without porting the head at the same time? Not sure. 450bhp crank?
5) 276 / 10.4 Getting a bit brutal. Needs machining and stiffer springs.
460bhp crank - may have maxed turbo flow here.
So - looking at either 264 or 268 cams - erring on 264 as it needs to be very 'streetable'. Anyone used these??
Cheers
410bhp crank?
420bhp crank?
Cheers
