Wheel Speed/ABS Sensor
1000 Views 2 Replies 3 Participants Last post by  bobg450
Okay one of my sensors are snapped clean off. Fing mechanic didn't retap it for me. So I'm stuck doing it. I don't have any proper screws.
Would zipties work until I can get a retap and proper bolt.
I figure if its tight to the proper space it will run fine.
Right?
1 - 3 of 3 Posts
I would say no. When I had issues with mine the ABS was very unpredictable.
Wait until you find out what dealers charge for those screws...
As much time it would take to get it in with the zip ties you could probably have those screws tapped and backed out.
Yeah, good luck getting them out. I think they are "locktited". Drill and tap to a similar size. And keep the alignment and 1mm gap. Good Luck.
1 - 3 of 3 Posts
