1 - 1 of 1 Posts
ok so i finally decided i need to get adapters so i can get some nice wheels. The adapters will be one ince thick changing my 4x108 pattern to 4x100.
Are there any problems with using adapters?
Also, the rota slipstream wheels i want are 16x7 with a 40 mm offset. The wheel offset calculator found here - http://toy4two.home.mindspring.com/offset.html - tells me that The clearance from stut housing to the inside of the wheel will be 20mm LESS The outside edge of the wheel will EXTEND an extra 6mm. In american that would be .7 inches closer to the strut and .2 inches closer to the outer fender edge. So would the wheel being pushed out an extra inch by the adapter cause any rubbing issues?
im so confused lol
1 - 1 of 1 Posts
