Try not to loose any of the copper crush washers for the banjo bolts. They are small, and easy to drop.
While small hands do help, I have absolutely monsterous hands and I've been able to get em out just fine.So I think I'm looking at the oil feed and coolant feed lines. They are in a pretty tight spot so I see why small hands help lol. Well, I can't get a socket on them, so what did you guys use? I can fit a box end, but I'm afraid it may round off.
I had to find some that were american and too small and dremel them out in the center so that they would work. You can only do this for a couple of them (I forget which ones, but I'm pretty sure it was the coolant lines), the others, you need to order from eeuro. I have absolutely no luck finding crush washers for the metric banjo bolts we have.Well at least this is sorta on topic..
Does anyone know what size the copper washers are? I want to replace all of them and just need to know the size so I can go to Lowes or Home Depot...Any ideas?
whoooaaaa!!!While small hands do help, I have absolutely monsterous hands and I've been able to get em out just fine....
Never had such luck... I tried every parts store in town (including AutoZone, VIP, Bond, Sanel's, A&M, and NAPA). All with no luck.When I needed copper washers, I went to autozone and sized up some banjo fuel line washers that worked perfectly.
