I recently upgraded a few components on my sonett and now im having a bit of a problem
I replaced the intake manifold and carb with a weber 2 bbl and ive got it up and running everything seems fine ..... I also lightened the flywheel
the clutch is "disengaging" or something to that extent
when i go into gear i do not get any grinds ... and when i release the clutch under acceleration is fine, but if i accelerate heavily, the clutch dissengages and when the when the rpm's drop .... it re-engages
it does not feel like its slipping it feels like its dissengaging because when it grabs it grabs hard and you can hear it ... makes kind of a clunking noise .... also when i slowly accelerate to say 4500 rpm's and i release the throttle, the rpms drop to idle, and i have to slowly bring up the idle in order for the clutch to grab again
i am completely lost, and hope someone has gone through this before and knows what it is ... thanks in advance!!!
al
