1 - 2 of 2 Posts
Does anyone know what is reset when you unplug your battery? For example I know the MPG is reset...But do you lose performance because the ECU has been rebooted and needs to be re-programed over time??
HNNLIC
The ECU is also reset, if the negative cable is off for about 15 minutes. You won't lose performance but probably gain for a limited time since the computer is supposedly learning out you drive.
This also helps to reset a CEL light after the problem has been fixed.
1 - 2 of 2 Posts
