1 - 5 of 5 Posts
Two questions.
1) How imperative is it to have new copper crush washers or have them surgically clean? I cleaned all of them off, but I have an oil like at the oil filter connection.
2) How tight should these be? I had a coolant leak near the AC compressor, I tightened the bolt (though it was already very tight) and that cleared up, but I don't want to strip or over tighten the oil filter connection. I cleaned the washers before I put them in, but I'm wondering if a spec of dust will cause an issue (And hence the leak, if that's the case) or should I just tighten it and give it another go? Thanks TSL community.
You should be able to find them much cheaper than that. Try the oil section of an auto parts store, or call around to a couple of different places. A CarQuest near me had the puffy crush washers, which actually do crush when you tighten them, unlike most so-called "crush washers", and they really sealed everything up. I had a couple of little drips before putting them on. I think they might've cost me $2.00 each, which I thought was ridiculous for a washer. Another option is to give them a light sanding to clean the old ones up. I had to do that with some aluminum crush washers that came with a pair of Earl's banjo bolts.
1 - 5 of 5 Posts
