I figured out the passenger side wiring harness. I was going the wrong way with it. Instead of trying to remove it from the car from the outside, I just pushed the big grommet inside the car and was able to pull it all inside the car through the hole.. That will work for getting it painted.
Yes, I know it's filthy..
It will lay it all on the floor once I get that done..
Also managed to get the front wheel e-brake cables removed.. Good riddance to those things.
Lastly, I still can't find a good diagram of the ducting under the dash. I think I'm missing a piece. Can someone verify?
There is a duct that comes straight down the middle in the back. It is behind the wide duct in the pictures and doesn't seem to connect to it at all. There are inserts to accept screws, but I am missing whatever piece attaches to it.
