1 - 5 of 5 Posts
Have to replace this on my viggen (drivers side), been been spitting fluid for a while. Just wondering if the 'differential oil seal' on eeuro is the same part.
http://www.eeuroparts.com/Main/PartDetail.aspx?id=55353153
Will be doing control arms/ball joints (poly bushings through GS), swaybar endlinks (poly bushings), water pump, serp belt/tensioner/idlers the weekend of november 6th-7th...putting off the TLC for far too long!
Thanks
Chris
Yep that is the seal.
How many miles do you have on the car? Any vibes while accelerating? The differential bushings wears which then causes the axle seal to weep.
It's also possible just the seal is bad.
Discussion Starter · #5 ·
Awesome, thanks for that. Installing the parts isn't the problem, it's figuring out what the parts are! If I have anything to add on any of this work I'll be sure to post it up.
Chris
1 - 5 of 5 Posts
