1 - 3 of 3 Posts
Hey, just today i started to get the info display .
I went out and the cap was tight. So i took it off and put it on and clicked it 3 times.
Then after school the light came on again.
Whats the cause of this??
The temperature was around15 degrees, so would it be the gas cap gasket?
Thanks
did the display say it was the gas cap or was it the check ingine light?
if it did say that then most likely it would be the cold it makes everything stiff and can cause problems when tigtening it down or if a bit of moisture gets up there and freezes it can cause it to read that way but most likely its nothin to worry about
1 - 3 of 3 Posts
