Tie rod ends.
5K views 15 replies 8 participants last post by  mr.jenkins
Ok, so Im 90% sure my tie rod ends will need to be replaced as the last time I took a peak at them they were in sad shape and Im going for an alignment on Friday.
Anyone know how big of a job this is (DIY wise?) and or how long/how much a shop would charge to do it if its too much hassle to do it myself.
-Coop
How simple is the job? You mind summing it up?
I assume....
1. jack up car, remove wheels
2. lube up bolts.
3. remove old bolts
4. install new ones
Is that it?
Is there tension on these parts?
How about the torque of the ends?
Nope, no tension on the parts. You will have to remove the nut on the bottom of the tie rod and hit it with a hammer to pop it out though. Then there is a sleeve that you have to remove the tie rod end from.
Yeah, pretty much a straight forward repair. The time it takes depends on the person doing it and their mechanical skills. I took me and my friend half an hour to do both sides but that was on a lift and taking the wheels off with an air gun. In a driveway I would probably give myself 1-1/12 hours without running into any problems.
I'm wondering how much of a bitch the rusted on bolts could be. My car has three winters on it in Maine, florida car before that. Rust is no issue at all, but still.
Remember to count how many turns it takes to get the outer tie rod end off of the inner tie rod. When you put the new outer tie rod on, just turn it on the same amount it took to get it off. This will keep your alignment somewhat close to what it was (but you still need to go get it done).
What you guys need is some good penetrating oil. I have used them all even P.B. Blaster but have never seen anything as good as Aero-Kroil. You can buy it off the internet there website is www.kano.com. This stuff is unbelievable. I had a flat head screw in the brake drum of a 53 ford farm truck that was stuck. I sprayed it down and the next day it came right out, didn't even feel tight.
