1 - 6 of 6 Posts
Hello,
Can you recommend a good way to pressurize engine oil thru to oil squirters to check for flow?
Tried thru turbo oil return, even drip out of all four squirters, want to make sure flow is +++ good.
Thank you! :)
That isn't going to do you any good, the return from the turbo is not pressurized. You could try applying pressure backwards through the oil feed for the turbo, that would be part of the pressurized system.
Discussion Starter · #6 ·
Sorry - I meant to say turbo feed! the only point of entry was the turbo feed port and I could not seem to flow much oil. So I do not know if that piston is getting full oil flow or not although all nozzles were dripping the same during my attempt.
much appreciated response..! What should I be looking for in terms of oil flow? Spraying/gushing out?
1 - 6 of 6 Posts
