1 - 8 of 8 Posts
Last year I swapped in a Walbro 255HP into the fuel tank, after the stock pump died. Since then, I've been getting shit mileage(20mpg @ 75mph with or without AC). I've tried all of the usual suspects (o2 sensor, temp sensor, readapting, different DI cassette, etc). I don't see why replacing the fuel pump would cause the mileage drop(if I do 55mph i get ~25mpg), so I'm not really sure what else it could be? I've checked for leaks, and there are none that I can find.
Any thoughts?
You ever replace the fuel filter? After a fuel pump job - sometimes debris can get stirred up and clogg a filter... poor flow usually results in poor performance more so then fuel economy however. Still something to consider. Have you tried a fuel system cleaner?
Discussion Starter · #4 ·
yeah, thats what the SID reports. i calculate mileage every time i fill up, and the SID is within 1/2mpg every time.
bs42: yeah, fuel filter was replaced, and i've tried a couple fuel system cleaners with no luck
Did you partially pinch the return line so that the rail pressure is too high? What do the fuel trims look like?
This is what I was going to suggest after finding this issue in my 9-3 when I replaced the pump. Fuel milage has gone back to normal since fixing that issue, but before it would be around 20mpg all the time, no matter what.
1 - 8 of 8 Posts
