1 - 4 of 4 Posts
Temp gauge is not coming up off cold, no mater the operating temp. Where is the sensor and how do I replace it. I'm assuming that is the problem. I've searched the forum and cannot find a good references to it. Thanks
the sensor on a C900 should be at the back of the cylinder head near your distributor. N/A and Turbo sensors should be in the exact same place. Check that the female connecter is pushed on the sensor securely and double check there is not a breach in the electrical line before you replace the sensor itself.
I am sure they can go bad, but I have not had that experience. Maybe you knocked it off by mistake fiddling somewhere else.
good luck
Found and replaced sensor, located below the top radiator hose on the side. just around from thermostat housing. It was bad after it was replaced the gauge immediately worked.
Found and replaced sensor, located below the top radiator hose on the side. .
technically speaking that would be the back of the Cylinder head; considering the motor is installed backwards:winky:
1 - 4 of 4 Posts
