Had a question on the banjo bolts for the td04-15 turbo. Where can I get adaptors from big banjo bolts to little banjo bolts. I swapped out the old garrett on my 97 and installed a td04-15 and need to either find some new lines, which I do have some but dont match up to the 900 block. So i am guessing just installing some type of adaptors for the turbo. Any ideas where to get them or best way to mod it up?
One more question. I took the turbo out of a 2007 9-5, it has a shorter compressor side and a bigger inlet tube. They changed in 2006 and up on the 9-5, 2005 and lower has a smaller inlet tube and the normal td04-15. Any reason why they did this?
Thanks
Thanks
