Hi there!
I'm intend to build a hybrid drag vehicle, it will powered by a b234 FPT powerplant. In stock it's around 200HP to the crank. What modifications do I have to do to reach the target horsepower limit?
In my country I can easily buy new Borg Warner K03 turbos for bargain (thanks to Audi factory in Győr). Of course the K03 is too small for 400HP but I thinking of a twin turbo option. I checked the K03 turbo maps, in twin turbo option its able to charge the engine from 2900rpm to 6900 rpm with 19 - 21 psi.
Are the stock internals of the engine strong enough to endure that much power? In other thread I read about a B234R that holds around 600HP with stock internals expect the pistons, but its a B234R, not a B234.
The mods I have listed to myself yet:
- Additional Intercooler
- Big oil cooler
- ARP headbolts
- Custom exhaust system
- Eliminate the balance shafts
- Stand alone VEMS ECU
- Larger fuel injectors
- Additional fuel pump
- With the stock valve springs can I rev the engine up to 6900rpm???
- Big oil cooler
- ARP headbolts
