T5 info is at the bottom of the thread.
Here's how to short belt your T7 when your AC compressor decides to begin its death rattle:
(Tweek, please embellish this so it doesn't sound so retarded)
1. Read the Saablink search results for "short belt," disregard anything that mentions a 6pk 2345mm belt size. That's the size already on the car.
2. Open your owner's manual to the specifications section.
3. Buy 1805 mm belt/71.06 inch belt.
4. Ask Tweek nicely if he'll do the work.
5. If no Tweek is available, then unbolt the strut brace and jack up front right passenger's side wheel.
6. Remove the wheel and remove the panel in the middle of the wheel well.
7. (Do something I didn't catch to make it easier to remove belt.)
8. Remove belt. Struggle.
9. Keep trying to remove belt and then loosen mounting bolts on air box to make it easier to remove belt. Loosen clamps on the crinkle hose and remove the hose.
10. Thread new belt following diagram in specifications section of your owner's manual but bypass the lowest right pulley, which is the AC compressor.
11. Get ready to retension the belt. If a Tweek is doing the install, call DeLorean and PaulH. to come help when Aireeca freaks out about potentially saucing the car by pulling too hard during the manuever.
12. Reassemble air box, wheel, brace.
13. Start the car up and, ahem, "see what happens."
14. If Tweek is involved, buy him a Gatorade and a water because that's all he'll take in return.
15. If no Tweek is involved, buy yourself a Gatorade and prepare to roll in your AC-less, happier 9-3. Woot!
Biggest important thing to remember:
The length of the belt that goes around the AC compressor is 2345mm which is NOT the length for the short belt delete. The real belt sized needed for this is 1805mm/71.06 inches.
Belt Part Numbers? Oh yeah, I got 'em...
Gatorback 4060710
Duralast 884510
Saab 4961058
JUST IN FROM TWEEK!!!
Late NG900s and early OG9-3s take a 1815 mm belt for the short belt/AC bypass.
Gatorback 4060710
Duralast 884510
Saab 4961058
