1 - 7 of 7 Posts
Sometimes when I go to start my car it starts right up then dies then I start it again and it runs fine? any ideas?
Also what kind of vac pressure are you guys running at idle?
Thanks Matt
for a c900 or 9000 idle vac is in the range of 15-20. Check your MAP and your idle air controller. Could be wires or the actual units... if you have a c900 or a 9000 anyways. If you have newer - not sure which route to go.
My vac at idle is around 16
well as goes your vac. I'd say it's about as good as it gets. Seek elsewhere for the problem. I just saw you sig and noticed it's a 94 900. I'll think about your prob. and see if I can figure it out for ya. I'm not too familar yet with the 94+ Saabs.
Discussion Starter · #5 ·
Thanks for the help
this happened to me when my belt was about to go, it'd die because the belt wasn't spinning freely enough, my tensioner and idler pulleys seized, check your belt dude
~justin
Discussion Starter · #7 ·
Thanks I just replaced my belt and all my idler pullys about a month ago .
1 - 7 of 7 Posts
