1 - 8 of 8 Posts
It's a 97 900SE turbo. Not grinding sound just a squeak. I do not hear it when getting into the car, only getting out.
HNNLIC
I think a little more info would be helpful. Where does the noise sound like its originating? Is it loud or soft? It is high pitched, or a grinding noise? Have you heard the noise in other situations, other than just exiting from the car?
Discussion Starter · #4 ·
The most likely culprit is the front Inner antiroll bar bushings. These are rather common. Usually only takes a spray of teflon lube to cure. It is hard to diagnose a noise without hearing it though... :wink:
Discussion Starter · #7 ·
I'll try the teflon lube. Thanks
1 - 8 of 8 Posts
