1 - 5 of 5 Posts
Finally had my new 99 9-3 towed home today. Right off the bat, I noticed that the SID is completely out, however battery seems to be dead so not sure if related. Also I cannot get the key out of the ignition. Also did all 9-3's come with keyless remote? I only have one key and no remote
UPDATE
Got the key out. Did not realize battery was dead until I tried to start and nothing.
Okay, if the battery is dead... then your SID is obviously not going to work...
What gear is the car in? If it is a 5 spd, the key can only be removed if the car is in Reverse...
9-3's came with keyless remotes, you can get one from a stealership for $.
1 - 5 of 5 Posts
