Impressions of the Rack brace and intake (cont.)
The ticking you hear is the Evap Purge valve (also known as the thingamabob from your pictures
) that goes on the tab that you bend out of the heat sheild.
The stainless part transmits the noise more than the stock one. It's totally common, and nothing to worry about.
I had the some sound on my old 9-3, as well as a few other people.
Palmer,
I was driving to work this morning, and it was driving me crazy.
The sound is most prominent above the dash; pop my head below, into the footwell, and the noise is so faint that I can barely make it out. I thought it might be the 10mm soket that I dropped in the engine bay, rattling, but your quick/clear/concise explanation put my mind at ease. Thank you so much.
I'll have to think of a way to isolate the thingamabob with some kind of dampening material. Currently, the rubber bits must be worn out and the plastic may be contacting the aluminium shield. The noise sounds akin to a jackhammer in a distance... tikatikatikatikatikatika...
Now that I know that it is benign, I'll just turn up the volume on the news radio station (AM 1000 in Seattle area). ...after $1500 in performance/accessory parts in ONE SHOT, my FM radio privilages have been temporarily suspended.
...or drive with my head in the footwell???
The sound of the intake is louder than expected.
The diameter of the MAF sensor inlet is MUCH larger than that of the c900t that I had (as is the compressor), so I had somewhat of an idea that the sound would be loud, but not THIS much :shock:
Steve,
I printed out your pics and that of Nick's on GS' Gallery albums.
That was all that was needed. The rotating of the sensor was the only interesting part.
The rack brace is quite a marvel of an item.
A simple design to take up the slack that SAAB left out in design/production makes a world of difference. The results are none short of stunning. It's a different car, altogether. ...and to think that I still have the 22mm ARB, 6-pt harness, and the Koni package to install... Woohoo!
I can live with AM radio for a good while :twisted:
