turbo1992 =ck the turbo bypass valve or hooter valve. its located just under the dstributor. pull the vacuum line off from the intake and suck on it to see if it holds vacuum. if it doesnt hold then its no good . if it does hold vacuum its good. that solved my bucking problems when letting off the gas.
