1 - 20 of 21 Posts
i have had two different boost gauges and both have read that i peak at 17 psi. i am currently running no tune but i have an intake and saab sport exhaust. 17 seems realllllly good for stock tune, or is that just me....
i have the same setup on my 97 se and my boost gauge says 15 psi w/o a tune as well, and yeah im gonna have to agree for stock tune that's pretty good but y do get more? that is my question. do you have a 93se or 900se?
I too have a 99 9-3 SE HOT and have gotten similar results.
I'm surprised it's that high
would a '99 viggen be similar or even more?
I though T7 was torque request, so it would request PSI to reach desired torque level, up to 20psi. I know on the viggen promotional video it said it would boost up to 20 or 21psi.
Um, I thought 1999 HOT's ran around 13psi stock? Unless it is T7 HOT 00-02 03vert.
What year is your car.
stock in my viggen (t7) i would boost around 12 most of the time. on my stage 3+ tune i might get 20 on a rare occasion.
I was pretty sure the non-hot 9-3 was 12.1 psi or so and hot was like 14.
B204L boost request is set at .75 BAR
B204R "HOT" is .99 BAR
Base boost is .40 BAR
B205L is .79 BAR for manual, .63 BAR for Auto
B205R is 1.00 BAR
Base boost is still .40 BAR
-From the WIS
0.75 BAR = 10.8 PSI
0.99 BAR = 14.3 PSI
I was pretty close.
B205R is 1.00 BAR
-From the WIS
Sounds good then. Obviously promotional videos lie.
So even if his is T7 HOT, it still would be around 14.5 PSI.
Discussion Starter · #13 ·
i can 100% assure you there is no tune, its a 1999 SE HOT 93. i am looking into getting a jzw stage 3 soon but i have a picture to prove the 17 if there is doubt haha. and its T5 software on 99 SE HOT's.
Then you have a problem with the waste gate or BPC.
Or a bad boost gauge. Stock t5 overboost fuel cut is what? 16psi?
Discussion Starter · #16 ·
yeah i thought it was 16 as well, hints my concern. i mean its cool getting a lot of boost but it seems something is up.
If your not hitting fuel cut, then either your gauge is wrong or its not a stock ecu.
Discussion Starter · #19 ·
it has to be my gauges. i would know if my ecu was not stock, i will look into the gauge set up and see what i can find then.
1 - 20 of 21 Posts
