1 - 4 of 4 Posts
$100 less than new is a pretty good savings though. It might need 1 hour of body work and $30 in paint/supplies/hardware to be looking good again. That's a lot better to most than $200 plus paint, especially when they're so difficult to find in good used condition.
Good used condition ?
As you mentioned it is not your listing I'll make the comment otherwise I wouldn't rain on your parade.
A busted bolt hole & a full length crack on the grould rub wear underneath side does not quality as good condition. The bolt hole could be patched but the crack is fairly terminal as it will break the next time the ground is rubbed on a parking ramp etc. Expecially with aero or lower springs.
1 - 4 of 4 Posts
