Long time no post! but its good to be here
I am working on manual swapping my 2005 9-5 using parts from a 2002, and figured i would start something to document the important bits. If you are reading this i assume you know the nuts/bolts end already, so i wont go into that.
Electrical
Below changes are made in the h16-7 plug (wis name) this is the big grey transmission plug that is more inside the engine bay
Under dash electrical
Last Step, remove Trans computer behind glove box.
Other notes,
-my donor car being a 2002, had the older style key, i found you Can swap key barrels from an 03+ car into an older shifter counsel. doing this will keep your car on the same key.
- Clutch pedal housing, These were different from year to year, although some parts of my 05's were pre-drilled, they did not have the lower clutch switch bracket built in, also the left and right side of the clutch pedal bracket seem to be a "matched set" as there are indents made to line up the assembly. Make sure to pull this whole assembly from your donor car when attempting the swap. Installing the clutch pedal is the single worst part of this job. and must be done with the transmission removed from the car due to bolt access on the firewall.
- When in this project, its a good time to replace shifter bushings, drop/clean oil pan, and inspect suspension components. No reason to skimp now.
Electrical
- Pin 12 & !4, these go the the reverse light switch on the manual trans, extend with correct plug for reverse light switch.
- Splice pin 11 &15 together, This completes the starter circuit when car no longer has neutral safety switch
- Splice pin 13 & 5 together, This is for the cruise control brake and clutch switch
- lower clutch switch is the starter interrupt, this goes in line of the main starter relay which is located less than 1 foot away from the switch. This interrupts the red wire from the starter relay
- Upper clutch switch is used for the cruise control This switch interrupts the signal wire from brake light switch. 9-5s have two brake light switchs, the one with the smaller gauge wire is for the cruise control. connect upper clutch switch as an interrupt of the cruise brake light switch
Other notes,
