1 - 5 of 5 Posts
Hi
Got a 2001 9-3 vert with low pressure turbo 205E motor.
Fitted new supposedly ceramic pads to it, but they are even worse than what it had before;
Original pads (not readable as to what they are) were OK but required a fair bit of effort to stop.
New ones seemed to bed in OK, but later deteriorated so feeling quite unresponsive until a lot of pressure on pedal.
As the car is for my girlfriend's daily use, this is not great.
Can anyone recommend good pads for normal street driving that I can use; Preferably ones that I can buy in Australia or nearby.
I would also welcome any other suggestions about improving the brakes.
Wonder if some twin piston calipers may be able to be fitted.
Also trying to find a good source of Parts for Saabs in Australia or preferably Western Australia. Any suggestions?
Thanks
Not sure about availability in Australia, but Akebono is typically the brand I goto for a generic daily driver. Also, if you haven't had the brake fluid flushed in two years, do it. You'd be amazed at the difference it makes.
Thanks will try bleeding it. I emptied the reservoir and put fresh fluid in when we got it, but my car hoist was clogged so did not do any more.
Akebono available but from premium outlet; Silly prices; Still looking.
Hi
Thanks
I recently installed new disc pads all around plus new front disc rotors
I used standard parts nothing special, off the shelf. I have found with experience hard pads tend to wear your disc faster, cheaper to replace pads than rotors
Parts
I suggest Steve at NSW Saab Salvage, he is a wealth of knowledge as well
02 96276834
1 - 5 of 5 Posts
