1 - 7 of 7 Posts
HNNLIC
I found a 19x8 rim that I'm considering putting on my car. The offset is 40mm. I don't know much when it comes to offset, but will rims of those dimensions fit on my 96 900 SET?
You should be ok with the wheel fitting. You might get some rubbing and your tire is going to be little more than a rubber band but man it will look HOT with a 19 on your car! Go for it!
With that design and the super low profile tire, you are going to be much more likely to bend a wheel than with a stock viggen wheel...unless these are forged? Do you know what they weigh?
HNNLIC
Discussion Starter · #5 ·
Not sure on the weight. I plan to have 40 profile tires though. I may have to go 35, but hopefully not.
1 - 7 of 7 Posts
