1 - 18 of 18 Posts
a car i am looking at needs a new head gasket. how hard of a job is this. could i do it myself?
thanks
see my post here: http://www.saablink.net/TSL/saabforum/viewtopic.php?t=2559 has pictures - get a Service Manual - makes it easy as changing a light bulb - but be prepared to make this a few day task - as one SHOULD have the cylinder head machined. If you have any questions further more - don't hesitait to ask! Good Luck! (took myself and DeLorean about 13 hours due to a 3 hour binde on a mis-threaded exhaust stud in the NEW head)
It is not that bad of a job. if you get a bently service manual it lays it out rather well.
Only problem I had with the bently instructions were:
It said to remove the exhaust manifold THEN remove the pass side engine mount.
I found that removing the exhaust manifold was not possible unless you FIRST removed the engine mount.
this was on a C900T a NA might be different.
Ian
Hey Turbokick, it's lucky for you that Burns runs through head gaskets like other people run through lightbulbs! :twisted:
Seriously though, it's not a tremendously difficult job, especially on a C900, but head machining is pretty critical. The tiniest flaw, or shred of old gasket , can cause you to blow it again....(Uh, I did this on my 86 900T...)
Once its out, you might as well have it ported and have the valves re-ground...
Actually - I run through lightbulbs like ppl who own Neon's run through headgaskets. This is my first headgasket I'e ever had to do on a car - the ng will be the second. 8) :p
actually I rather like the haynes manual for headgasket replacement. IMHO, the bently is over detailed and a little too tricky to follow.
You sure that was only two?
:lol: :lol: :lol: :lol: (Just yanking your chain!)
I've only done two....The first was because of my own stupidity, gunning it down I-95 to Rhode Island. The second time was like a month later, after NOT having the head machined. Scraping it with a putty knife doesn't count, I learned!
Only tips I have are these:
Sometimes a little dab of permatex will help it adhere to the curved parts
Follow the torquing pattern religiously....
This i'm sure will bring up some more disscussions....
I suggest re-torqueing the head between 500-700 miles after the job. By this I mean in the correct pattern, 1 bolt at a time. Back it off, then retorque it according to spec.
Sports Car Service tries to do this on all the HG jobs, about 75% of them come back to get it done. I think they notice less chance of another blow.
The down side-breaking a bolt. My dads 1 friend broke a bolt while doing the re-torqueing. I did mine in 45F weather (warmest day i could get) and did not break a bolt.
But I know delorean never did this, and BS either.......they are still going fine. It's up to you.
Ian
well here is part of it. if you clean the threads of the bolts and are doing a head gasket with a freshly machined head, you are putting 2 100% flat surfaces to 2 flat surfaces. they don't specify a head re-torqueing with new cars, why would you need to after a job like that?
a counterpoint here is if you have NOT had the head machined and are just doing the gasket you probably will need to retorque it in about 1000 miles to get a good seal out of it, only because the head may not have been 100% smooth and threw off the torque readings of a couple of the bolts. that in itself could lead to an early head gasket failure. and that IMHO, is really the only reason to re-torque a head.
I think I'll stick to paying the extra $60 to have the head checked out and machined before I put it on.
Discussion Starter · #10 ·
thanks for all the help but the car has been sold to someone else :(
Discussion Starter · #12 ·
yep for now anyway :cry: :cry: :cry: but i may have found another potential saab this one with a blown auto trany insted of a head gasket
Dude, what's your budget? You can find something decent for a grand or so, and not have to spend big money and loads of time....
Give us a dollar figure, and we can try to find something for you. There's a 9000 Aero that's going for about $2K on Ebay now....
The NG900 autobox is really sturdy, so if it's blown I'd suspect it was driven by someone without a clue. Check for evidence of a tow hitch....
Discussion Starter · #15 ·
actually im looking for c900T not ng so the blown autobox is pretty common. as for a dollar figure around $600 or less i also dont really mind spending time working on a car because it is a learning experince and as i will be doing all repairs to the car i get.
how can is get in contact with SMOKINSPG where can i see the car online?
Burnside you must go through a hell of alot of lightbulbs then becuase Neons average 4 to 6 head gaskets in there lifetimes!!! Speaking from personal experience on this one!!
I did the HG on my 86 C900 and I never retorqued my bolts either. I did however not use the bolts that came out of the car but chose to invest in a new set of bolts for it. Thats something I always do that alot of people say is a waste but I would rather make sure that I dont have to do it again or have leaks than to not spare the extra $40 bucks on the bolts.
1 - 18 of 18 Posts
