1 - 12 of 12 Posts
I just found out that my two O2 sensors in the front of the car are both before the Cat converter. I keep getting codes could that be why?
Yes, That would make sense. Since the car is looking for higher(?) O2 levels after the cat, but is not getting them.
Wait, how did you get 2 o2 sensors before the cat. It seems like something that would be pretty intentional.
Tboy
Maybe "lou" made a mistake?
Discussion Starter · #5 ·
Yeah I called them It would seem that they made a mistake I have to bring the car over so that they could check it. But the car drives like crap unless its in sport mode. Plus the code that its getting.Code P0172 & P0420
One should right on the top of the down pipe, just after the turbo, then the cat sits right next to that and then the rear o2 is down behind the oil pan. Next to impossible to get 2 o2s before cat.
p0172 is a rich condition on sensor 1
p0420 is a catalyst performance issue
possible plugged or deteriorated cat?
Discussion Starter · #7 ·
Yeah I'ts a brand new CAT. Its not even a month old. But I am going up to lou's probably today to have them take put the O2 sensor in the right spot hopefully.
Ah, how does that happen?
Its kinda an obvious mistake.
Deez Nutz
One in front of the cat, and one after.
This is how the car knows the cat is working.
Someone who does exhaust for a living should know this.
Now you have a extra bung for a wideband. :)
1 - 12 of 12 Posts
