1 - 3 of 3 Posts
This is for the engine only as of now:
1 Alternator Mount Bushing (urethane) (7541451U ) - $7.90
1 CRANKSHAFT PULLEY (9107665A ) - $64.90
1 Distributor Cap (03010 ) - $3.60
1 Distributor Rotor (04168 ) - $9.03
1 Fuel Filter (71039 ) - $9.94
1 Ignition Wire Set (8817520 ) - $38.99
1 Oil Pan Gasket (trans-engine) (7514946 ) - $9.99
1 Exhaust manifold gasket (7518996 ) - $12.49
1 Valve Cover Gasket (8822041E ) - $14.29
1 Intake Manifold Gasket (9126277 ) - $6.90
1 Oil Pump Seal (9173576 ) - $4.19
1 Rear crankshaft seal (behind flywheel) (9174202 ) - $7.90
1 Head gasket (9181348 ) - $15.09
1 Thermo fan switch (92degree) (4086708 ) - $6.99
1 Rod Bearing Set (std) (0269308 ) - $32.79
1 Main Bearing Set (std) (0269357 ) - $42.79
1 Thrust bearing set (8347270 ) - $6.79
1 Piston ring set (7520513 ) - $47.90
1 Timing Chain (endless) (7500697 ) - $34.90
1 Water Pump Kit (8817900L ) - $43.49
1 SPARK PLUG SET (4) (BCP7ES ) - $6.90
2 Seal Ring (large) (4161162 ) - $0.79
2 Sealing Ring (small) (4443883 ) - $0.69
1 Turbo Oil O-Ring (return tube) (7502263 ) - $1.75
1 Turbo Oil Gasket (inlet) (7507700 ) - $1.09
3 PVC Bushing (valve cover) (7515190 ) - $0.99
3 Intake Manifold Bushing (vacuum fitting) (7515208 ) - $0.99
1 Turbo Oil Gasket (7518970 ) - $1.19
1 Oil Filter Housing Gasket (7566433 ) - $1.09
1 Oil Pump O-Ring (9125824 ) - $2.09
1 Urethane swaybar bushing kit (1 kit per car) (8990087U ) - $42.90
1 Upper Chain Guide (7505845 ) - $5.59
1 Timing chain guide (tensioner side) (8858276A ) - $18.99
1 Timing chain guide (9133505 ) - $19.90
1 Turbo Gasket (to manifold) (8366262 ) - $2.89
1 Alternator Support Arm Bushing Kit (Urethane) (9354770U ) - $6.49
2 Side Motor Mount (7545650F ) - $59.50
1 Front Motor Mount (7545668F ) - $64.90
1 Distributor O-ring (9176470 ) - $0.99
Total: $725.52
Did I miss anything?
Not sure where you buy your parts but why not opt for sets? Meaning timing chain “set” and head gasket “set” you could save a couple of dollars plus you get the little extra’s that you should replace like timing chain rail bolts (3) and valve seals (16) …. Both of which did not appear on your “rebuild” list
well - I looked for a timing chain set - they don't have them :( as for a head gasket set - I ordered what i wanted vs. the set cayse I am using a 2.1 head and intake.
I am buying all those parts and my trans parts from www.eeuroparts.com - all those above have now been ordered.
1 - 3 of 3 Posts
